Go Back   Offshoreonly.com > Owner's Forum > Activator
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 10-27-2006, 01:01 PM   #11
Yes, I'm from KANSAS!!
FunHome's Avatar
28ft Saber, 22 Velocity
Re: Totally/Partially Enclosed Trailer for 32 Stealth?
I've seen this done with a couple of Bass Boats, one had a top simular to a flat bed cover on a truck bed, it went up on hinges, I think the sides stayed in place and the back had door that flipped around and fastened to the side while launching.
The other had what looked like a hard fiberglass cover made to fit the top of the boat, that lifted on and off. It looked real heavy, it looked like another boat upside down when on the boat.
I guess these Bass Boat guys have to worry about locking up all of their gear while traveling to toury's and such.
I've thought about a hard cover that could go on over the cockpit and fit tightly enough to not let any water in, or you could use srink wrap tape around the edges. But this leaves the rest of the boat out in the open.
I've thought about this before also, to the extreme of even having a huge trailer (semi) to pull the boat and truck (short truck) into while traveling.
Sorry to snoop into this section and post, hope it is OK
FunHome is offline   Reply With Quote
Old 10-28-2006, 09:13 AM   #12
Liquid Fix's Avatar
http://www.performancetrailersaz.com/pace_aerosport.htm
Couldn't find a better picture.......LF
Liquid Fix is offline   Reply With Quote
Sponsored Links
Old 10-28-2006, 03:05 PM   #13
SmoothWaterSports's Avatar
Malibu Boats
Only problem with the PACE unit for small boats is that the roof is fixed. If you have a steep ramp once you get the boat in far enough to back off, you'll run the motor or your head into the roof before you get out the door.
Logistically the comment about semi-enclosed - front/top/sides 1/3 or 1/2 way back is likely the best route, unless you go a full 13'6" high for plenty of headroom.
Peter
SmoothWaterSports is offline   Reply With Quote
Trackbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Need to rent an enclosed car trailer.... Formula Outlaw Trucks, Trailers and Transportation 0 11-13-2005 09:10 AM
Wanted: enclosed trailer Team V Trucks, Trailers and Transportation 8 06-27-2005 08:59 AM
OT:Need enclosed motorcycle trailer JackL General Boating Discussion 7 11-20-2002 12:51 AM
Looking for a enclosed box trailer Xtremeracing General Boating Discussion 3 03-15-2002 06:39 AM
Search Engine Optimization by vBSEO 3.2.0
