Go Back  Offshoreonly.com > Owners Forum > Activator
Activator lift hatch struts >
Old 09-13-2017, 01:43 PM
Default Activator lift hatch struts
I don't own an activator, but I'm looking to see how man lbs struts you guys use on your fiberglass hatches ? I have a velocity and want to do a similar set up. 130lbs a side ? Or more ?
Thanks-
Bajajay98 is offline
Old 09-14-2017, 01:06 AM
Charter Member #394
SFOcean's Avatar
I use 80 lb struts on the 32's hatch. No upholstery on the hatch, just a scoop.
SFOcean is offline
Old 09-16-2017, 12:16 PM
It works pretty good ? Holds the hatch up. I just get nervous of the wind blowing and the hatch falling on my head haha
Old 09-17-2017, 12:23 PM
Charter Member #394
SFOcean's Avatar
Yes, they work well. Their efficiency depends on hatch weight and strut mounting location, good luck.
SFOcean is offline
Old 09-18-2017, 03:46 PM
I think mine are 90
Pez Man is offline
Old 10-13-2017, 10:52 AM
2jz
I just bought two 80lbs struts 24" extended because wanted hatch open as close to 90° as possible if i had to get in belge area. I ended up using only one strut. Light lift on hatch and it opens on it own.
2jz is offline
