X dimension ?
Old 03-21-2007, 11:37 AM
I think this has been discussed before. Mine is a 99 with a 502/Procharger set up @ 5lbs of boost. Approx 600+ HP.
My prop shaft is approx 1.5inch below the very bottom of the boat. The hull has a large notch. I run a 28 Maxximus turning 5000+ RPM. Gps speeds are +/-76mph with a good size load and 4 people. Hope this helps.
michigan troll is offline
Old 03-27-2007, 04:09 PM
AKA NoMoBoatin
I would ask the A/T expert on x-dim. and props.Just call CRB he knows all.
docmanrich37 is offline
Old 03-27-2007, 08:16 PM
I have a 28 AT, but it's a twin. However I have tried Bravo 1 props (26p) and they turn about 400 less rpm's than the Hydromotives. I labbed a set of 4-blade 27"p and reduced the diameter to 15" and can turn 5000rpm...speed is somewhere in the low 70's...no GPS so I'm calculating 72ish with 14% slip. As for x dim., I had to add latham spacers,1-1/2" to get propshaft 5" below straight edge off hull. I spoke with Bobby Moore and he recom. 4-1/2" to 6" below hull line. Of course so much different with a BB single. Good Luck!
spilman is offline
Old 05-07-2008, 09:33 PM
littledcsrodshop's Avatar
This is an old thread but does anybody else care to give some input on this ?
littledcsrodshop is offline
Black Wishbone
Sutphen
4
03-11-2008 07:02 PM
40FlatDeck
Skater
10
01-11-2007 10:28 PM
375stinger
Cigarette
0
11-10-2004 04:56 PM
Bajaforce
Baja
2
03-05-2003 08:09 AM
sambryce
5
03-04-2002 05:27 PM
Quick Reply: X dimension ?
