Any added-on bling?
#42
Atleast you could put OUR salt in your food. How 'bout that nice Virginy salt water?
Ok, now I have to go look at the boats. What plastic stuff are you talking about???
#43
Take a look at the fitting on the trim tabs that the indicator cables go thru and the tie straps on the steering ram hoses.
#44
It gets on any non coated metal on the transom. Tailpipes, steering rams, tie bar and props. It sticks to stainless steel worse than anything. When i got home last week I had to clean my props with on & off to remove it and then saturate them with CRC. It's just one of the things you have to deal with if you want to boat in the beautiful Florida Water.
#45
Lime-away is a lot milder than On & Off and CLR and still gets it clean. You can get it at the grocery store.
#46
Is that the same water I was wading around in where we grounded at the marina?
That plastic retainer on the K-plane comes with the plane. Now the builder has to sound stupid.....who makes them in SS?
#47
He's talking about the thru hull fitting that screws into the tab for the indicator cable. The plastic ones cost 23 bucks a pair and the stainless one 106 bucks a pair. Mercury makes both. The first time you put lime-away on the transom when your in Florida the plastic ones turn white and look like chit. The manufacters in the previous post use the stainless steel ones and AT uses the plastic. I've ordered some polished stainless blinged up ones to replace mine with from Stainless Marine. They come with a hose to cover the cable from the thru-hull to the tab connection and look really good. The OL at the Miami Show had them on it.
#48
Come take a look dude! We can grab some dinner on me...and you can bring a set of those 5 bladers you have hanging on your wall.
#49
I see that now.
But if we put all that stuff on at the factory, Mark wouldn't have anything to spend his money on! (except maybe Lori)
#50
I wouldn't be worrieing about that, you can't do it all and there is always something new and shiney comeing out. Still very nice of you to be concerned
