Drive Toe adjustment.
Getting ready to put the drives back on and was looking over some past threads, is the correct set up 1/8 inch toe in with the props turning out ? Props are bravo 4 blade 32's
Just want to get everything back to stock set up, I understand that things where switched back and forth a few times so I figured if I put it back to factory specs that would be the best place to start. Does Pat keep the set up specs on each boat on record ? If it aint broke dont fix it but if it aint right put it back to stock is my motto. The drives are just about done and getting ready to refinish all the hardware so I figured I would get all the stock specs to insure the right set up. Want to make sure we run good at this summer poker runs.
