Go Back   Offshoreonly.com > Owner's Forum > Active Thunder
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 08-18-2009, 11:17 AM   #11
chuckbeecher
Location: Anywhere from the Laguna Madre to JAX and beyond
glasstream
Quote:
Originally Posted by My Addiction View Post
Jeff... good info.
ICDEDPPL... That jet ski is going to slow down if it gets rough and your AT wont, you might go a little faster. Are you trimmed out at 78 b/c I thought it would be faster than that with a SC600?
I think everybody has a buddy with a 23' Rinker
You could be running out of hull.
Every hull will only run so fast no matter if you put 2000 h.p. in it. I forgot what the technical term for it is called.
chuckbeecher is offline   Reply With Quote
Old 08-18-2009, 04:42 PM   #12
98 ActiveThunder Tantrum
the guy I bought my 25 from had a 700hp 572, he said it would do 84 with a little more throttle to go but didnt want to turn the bravo over rpm . not sure if that was a GPS speed or not, my speedo says 78-80 when my gps is only on 73. something
My Addiction is offline   Reply With Quote
Sponsored Links
Old 08-18-2009, 05:16 PM   #13
Just a broke city punk
lil red's Avatar
40' Excalibur Hawk, Rinker 270 (wife's boat)
addiction your boat did 84 on the gps and had more if you wanted to push it past 5300 rpm, that boat belonged to a really good friend of mine, and i'm hating myself for not buying it.
lil red is offline   Reply With Quote
Old 08-18-2009, 08:53 PM   #14
Quote:
HA HA!! I love it. Tell Rob I said Hi It was rpms now that you mension it.
Old 08-19-2009, 11:41 PM   #15
Poker&Run's Avatar
Active Thunder
Oil temp sounds a little hi to me. Jeff had some good info there. Mayb a trashed oil pump? U need to figure out what is going on...You may have some predetonation going on too and will soon have a hole in a piston. If you had something happen in the outdrive that was severe enough to kill the engine while underway, trust me, it would be in pieces.
Try a compression check/leakdown test while you are at it.
Poker&Run is offline   Reply With Quote
Old 08-19-2009, 11:47 PM   #16
Poker&Run's Avatar
Active Thunder
Reading your post again....Where you said the ear muffs slid down and you heard a knocking sound. If you haven't been around these motors alot, the water that comes through the exhaust does make a slight knocking sound. Good luck
Old 08-20-2009, 02:01 AM   #17
StraightJacket's Avatar
38 Fountain Fever with #4's, ok so it really 35
problem found, Outdrive
StraightJacket is offline   Reply With Quote
Old 08-20-2009, 10:15 AM   #18
39' Sea Ray, 38' Nortech, 18' Taylor SJ
Quote:
Just hit it with that giant wrench you are holding. That should fix it.
jeff1000man is offline   Reply With Quote
Old 08-21-2009, 08:56 AM   #19
AT Cult Member #3
R Addiction's Avatar
'99 Active Thunder Tantrum
Seriously? Upper?
R Addiction is offline   Reply With Quote
Old 08-21-2009, 01:27 PM   #20
Quote:
I wish someone would hit me with the dam wrench , Maybe I would smarten up and get out of this hobby.
Yes , seriously.
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
