| OSO Sponsor |
| OSO Sponsor |
09-06-2009, 02:22 PM
Life is good lb:)
09 Active Thunder 37
cabins on 37
two different?? one with a cabin liner? what is the difference.. and tell me what i need..
09-06-2009, 09:04 PM
Forum Regulator
Active Thunder
Choice is yours. Most go for the cabin liner.
Non-liner boat can be heavier or lighter than a liner boat depending on what you want in the cabin.
You need AC/Heat, Pump-Out Head, and a few 110V outlets for a coffeemaker and cell phone charger. That's it. Nobody uses the microwave and hardly anyone uses a fridge in a true go-fast.
Brian Tillett
Active Thunder Factory Rep.
Web: ActiveThunderBoats.com
Email: ActiveThunderAVH(a)aol.com
09-06-2009, 10:17 PM
2007 37 AVH Active Thunder
non-liners are the best and fastest
09-06-2009, 10:32 PM
Forum Regulator
Active Thunder
That's because your cabin is so heavy, the boat is always going downhill.
Brian Tillett
09-07-2009, 07:28 AM
'08 37 Active Thunder
Huh? Pat told me going non-liner shaved about 700 pounds. And makes for slightly larger cabin.
But, you are right about the fridge. I have probably used it twice in three years. If I were to do it again I would go with the cooler. And you won't have to deal with the door coming open.
I do use the microwave to heat up water for coffee in the morning.
09-07-2009, 08:44 AM
Forum Regulator
Active Thunder
The liner weighs somewhere around 700 lbs & you are right on size. If you don't put the liner in the boat, yes you do save that weight, but you do fill in the cabin with components that add some weight back in. Clark's boat has a lot of intricate components in the cabin, (a bit more than yours) and hence it weighs a bit more. It sure doesn't slow the boat down though. It's a tank & a fast one at that.
Brian Tillett
09-07-2009, 07:26 PM
1998 32' Active Thunder
Quote:
Rode on Clark's boat coming back from the sand bar outing in Key West in 2-3's. Wife and I were lounging in the back seat talking at 85 plus. Unbelievable.
Long time cult member.
09-07-2009, 08:40 PM
Active Thunder
Quote:
Jeff....  Are you FINALLY joining the Cult??
09-07-2009, 09:04 PM
2001 Cig 38
So given a poker run configuration, a cooler, couple outlets and a head what does a 525 boat run for speed? I mean real world 4 people and 1/2 tanks?
09-07-2009, 10:30 PM
Forum Regulator
Active Thunder
Quote:
Ought to turn 87-90 depending on how much you invest in props.
Brian Tillett
| Thread Tools |
Search this Thread |
