Took the boat out.. ran awesome
Only put a hour running time on the boat.. On trim i cant seem to find the sweet spot yet.. 3-6 feels no different.. 1 " spacers... The boat has NO problem getting on plane.. still curious why their on their... on turns leans way more than im use to.. jury still out on the ride...no real chop yet...
Any help would be grateful.
Thanks Jeff
Thanks Jeff
Quick note on trim:
Use the tabs only for getting on plane. Other than that, leave them at neutral. (unless you need to correct for a list caused by wind)
As a general rule, you will only need to run the tabs at 1-2.5 ticks above neutral. Anything else will slow the boat down.
Best bet is to take the Tre class and you will learn more about trim then you will ever need to know, but worth the time for the class, and you will be confident in your settings as well as speed if adjusted properly.
