Used my Tantrum for the 1st time !
#44
I had a small fuel leak in mine. It was the hard line that went from the pump to the filter. You barely notice it. After I'd run the boat and shut it down, it was a very slow leak and I found it by running my fingers around the lower end of the line. Fuel was seeping out at the pump side, but very slowly. Replaced the line and no problems
#45
#47
I assume you mean water separator? Did you change the water separator? Did you remove it to make sure it's not double-gasketed (gasket from old separator still in place, not noticed when new separator installed).
Im pretty sure its gonna be just a hose somewhere or the filter . there is a yellow trail that starts just below the fuel filter in the front of the engine compartment . by the time we got parked and noticed it saturday it had time to dry up so we couldnt tell where exactly .
#48
yeh , thats what i meant . gonna get the boat out this weekend and start working on it . good idea about the towels . thanks ...
#50
