Very stiff steering
Is the a possibility a filter was never installed? It has Marine Machine steering and I can't see a filter anywhere? Don't see a place where one used to be either. Though maybe it jurst got removed by someone along the way? Any suggestions as to where to look on a 2000 37'? Only spot I cannot see is where the lines are running in the tubes of course.
The filter should be on the high pressure side. Trace the line from the back of the pump. the filter should be between the pump and helm unit. Usually mounted on the stringer closest to the pump.
http://www.everettperformance.com/PD...se_Drawing.pdf
I have the same problem with mine at idle. Its better when rpm about 1200+. My pump has been drilled and it did make a slight improvement. I dread docking/loading. !! Anyway I was told I needed to replace the pump. May be interested in one of your pumps Faster Daddy.
Pat told me that there is NOT a filter installed (at least on Savage w/ 500EFI)
