Fuse block, where to buy replacement? >
Old 05-31-2019, 09:32 AM
Default Fuse block, where to buy replacement?
I need to replace on piece (as it appears to be 3 sections) of the under helm fuse blocks on my boat and seeing as there is NO room to add a larger one, im having trouble finding a replacement that has 5 fuses and is only 2-1/8" long.
Any one have any leads?
TooLateVTEC is offline
Old 05-31-2019, 10:15 AM
Did you check Blue Seas products?
ALL_IN! is offline
Old 05-31-2019, 10:28 AM
Yessir, sure did. They have nice looking stuff, but nothing that matches what I have in there now.
Old 05-31-2019, 11:18 AM
I looked around an also came up empty as you did. If all else fails, maybe remove the block and use a buss bar. Then attach individual inline fuses
AllDodge is offline
Old 05-31-2019, 11:42 AM
"Unregistered Gun"
Jim Diesel's Avatar
Several options on Del City, they don't give dimension specs but their customer service has always been helpful.
https://www.delcity.net/store/Fuses-&-Fuse-Accessories/
Would this work?
https://www.delcity.net/store/AGC-Fu...50093.h_651245
Jim Diesel is offline
Old 05-31-2019, 02:14 PM
I have some they are Hella HLA005993032 Give me a call 317- five o two 2812
Morry
harsin is offline
Old 05-31-2019, 11:04 PM
Have you tried Ebay. Last time I checked they had over 136,000 listings. I'm sure you could find one that would fit your needs there. They have been my "go to" place for most anything for a while now.
gofastboater is offline
Old 06-01-2019, 12:39 PM
Forum Regulator
Sydwayz's Avatar
Received 1,207 Likes on 523 Posts
I don't know where Pat sourced them from, but I had to replace one, and found the exact same piece at O'Reilly Auto Parts. John Hope (Whatever 37) told me about it.
Sydwayz is offline
Old 06-01-2019, 12:48 PM
Forum Regulator
Sydwayz's Avatar
Did some quick digging. This is it I think.
https://www.ebay.com/itm/Littelfuse-...AAAOSwenFc6fft
https://www.bonanza.com/items/like/5...W-1-4-Q-C-Term
Manufacturer page so you can dig some more:
https://www.littelfuse.com/products/.../ato-fba5.aspx
Sydwayz is offline
Old 06-01-2019, 03:52 PM
The littelfuse is rated at 15amps (thats total amps), I'm assuming one of the fuses needed is ignition which would be 20 amp, then add up the rest
The other doesn't list a rating
AllDodge is offline
