Go Back   Offshoreonly.com > Owner's Forum > Advantage
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 08-06-2009, 12:44 PM   #1
1993 Advantage 22' Citation
Prop for 22 Citation
Hello,
I have a 93 22' Citation and I am currently running a 23P Bravo 1 prop (3 blade). The motor will turn out 5200 rpm at WOT. I know better than to run it up that high but has any one had any experience with repropping their 22' Citation? Any suggestions on a prop make or size will be appreciated.
Thanks in advance.
Rich
produck1 is offline   Reply With Quote
Old 09-23-2009, 11:40 PM   #2
Charter Member #9/ Moderator
LakeRacer's Avatar
99 Advantage 34 Offshore
Took a while
but you finally get an opinion for your question.
5200 rpm is the right range depending on motor. If you want to drop the rpms I would suggest a 4 blade bravo one in 24pitch. It should drop your rpms 200-300, you might get better holeshot, won't blow out as easily and get really lucky with a couple more mph.
Art
LakeRacer is online now   Reply With Quote
Sponsored Links
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
