Go Back   Offshoreonly.com > Owner's Forum > American Offshore
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 01-28-2008, 07:36 PM   #11
Ran-Dom 32's Avatar
Fountain 42 EX
Quote:
Originally Posted by razor1115 View Post
Ran-dom,
How's the new project coming along?
Zack
I made it into a way bigger project then my original intentions, but it should be pretty sweet when i'm done, It's currently at Mitcher T getting a face lift
official 100 MPH Club member since 2008
Ran-Dom 32 is offline   Reply With Quote
Old 01-28-2008, 09:30 PM   #12
razor1115's Avatar
1999 35' Fountain
Quote:
Outstanding - Can't wait to see it!
razor1115 is offline   Reply With Quote
Sponsored Links
Old 02-23-2008, 07:25 PM   #13
2000 fountain 35 lightning classic
decided to keep it and use it for the summer...anyone have any idea what prop is best for my setup ? 454 procharger factory setup with bravo 1.... i got the boat but the prop was misplaced..
stevemamanfountain is offline   Reply With Quote
Old 02-23-2008, 08:27 PM   #14
american offshore
Banana
what is the gear ratio of the outdrive. most of the 454 boats powered with the procharger ran about 90 mph. Iis the engine a 454 magnum with square ports or the 7.4 with oval peanut ports. the magnums could take more boost and could last longer than the 7.4s because they have forged pistons , bigger cam and better breathing heads.
quest is offline   Reply With Quote
Old 02-24-2008, 12:02 PM   #15
Quote:
here are some pics.. please tell me what you think it is...
Old 02-24-2008, 12:03 PM   #16
some more pics
Old 02-24-2008, 12:05 PM   #17
there are only 105 hours on the boat...arizona it's whole life..never seen salt water...so i think i should be fine...i will run it stock....no more mods...
what prop do i need to put on there ?
i do have a brand new set of hydromotive intimidator q4's ..... they are 26 pitch or 28 by 15 or 15.5 if i remember....
can i use these...?
Old 02-24-2008, 03:30 PM   #18
http://www.offshoreonly.com/forums/s...=1#post2458012
here are some pics .... it would be great if i can use those props.. they are brand new and i think they are 28 not too sure.. cant tell if they are labbed ? i know they were 15.5 or something...
Old 02-25-2008, 08:07 PM   #19
the props i have are 28 x 15.5 .... hydro 4's never labbed..
can i use them on this boat ?
Old 02-25-2008, 08:52 PM   #20
american offshore
Banana
You have the 7.4 MPI motor which has the cast pistons and should be set up more conservatively than the 454 magnumfor good life. My best guess is that you can expect to get approximately 80 mph with this engine. If you have a 1.36 gear ratio the 28 pitch hydromotive should work just fine. if you have the 1.5 gear ratio you will need a 30 pitch bravo one prop. the gear ratio is marked on the sides of the outdrive.
At any rate I would put the 28 hydromotive on it to start and see what MPH and RPM ypu get. I don't know if the computer has been modified to let the engine rev to 5000 RPM or it is still limited to 4600 rpm. if you get up to 4600 rpm easily and hit the rev limiter then you know you need the 30 pitch bravo one or you can get the hydromotive re pitched to 29.
Trackbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
problems with my 454 mpi/procharger 98'AO 26.losing power... stevemamanfountain American Offshore 9 06-16-2008 09:09 PM
ao 26 ft . 454 mpi procharger questions stevemamanfountain American Offshore 0 06-15-2008 11:43 PM
26 with 454 mpi and procharger...have black smoke and misfiring issue... stevemamanfountain American Offshore 3 06-14-2008 08:11 AM
Questions about 1998 Gen VI 454 Mag MPI? TufEnuf Formula 2 07-01-2007 12:22 PM
anyone have install instructions for procharger M1 for 454 mpi snake plissken General Q & A 2 02-10-2006 06:38 AM
Search Engine Optimization by vBSEO 3.2.0
