prop options
prop options
i took some 5blade p5's off of my 31 and put bravo 4blades on. ive been very happy running fast nice control etc but, i just noticed 2 cracked ears so before i purchase something that doesnt work i figured i would see what everyone has luck with. current setup.. imco 1:26 drives 34p bravos turned IN. has anyone run cleavers? 5 blades? etc etc thanks everyone
ran mine last weekend hops out of the water at 110. Guess I need to find some boxes. Prop shaft is even with bottom of boat. would not come on plane without someone running to the front of the boat. Over all pretty happy till I blew a motor.
why do you think you need boxes? to solve your plaining issues? I have the same set up, running same speed, I had the props worked by Bblades & it carries the bow much better, planes without issue, & the hop cleans up after 90, running 34P labbed bravos & the tips have allot of cup in them
I hopped to 110 then started blowing the props out. I had to pull the motors so I figured if I'm going to do boxes now is the time. Also wont the boxes help with the hop?
i have stellings boxes on mine,i cruise at 70 with no porpusing,it will hop a little between 70 to 90,above 90,its as smooth as silk,right now i have a pair of 5 blade maximus,30p,but i need more prop,looking for bravo1 34 p or 32 p to try,anybody near chicago with a pair that i can try.
