Go Back  Offshoreonly.com > Owners Forum > American Offshore
Texas outlaw Challange Shootout >
Old 06-21-2013, 10:54 PM
Over 135 boats registered. I won the C2P2 class with my 3100 American Offshore at 141 MPH. Top Gun was Kenny Mungle with a speed of 171 mph with his 32 skater with twin 1500 HP motors.
quest is offline
Old 06-24-2013, 10:15 PM
congrats... what kind of horsepower do you have? and drives?
Brian
BC F1-90 is offline
Old 06-25-2013, 08:59 AM
twin 502 s with whiple chargers and B Max outdrives on 12 inch standoff boxes approximately 850 HP each engine
quest is offline
Old 06-25-2013, 09:18 AM
Default That is awesome.... to get that kind of speed with 850 hp..wow
That is awesome.... to get that kind of speed with 850 hp..wow... thank you and keep safe..
Brian
BC F1-90 is offline
Old 09-10-2013, 04:01 PM
must be a light layup 31 to run that number my 1997 wont go that fast
32agitator is offline
Old 09-18-2013, 09:31 PM
light layup. no wedge in tunnel, imco extension boxes, 24 inch long tunnel tab, 33 pitch herring 5 blade props
quest is offline
Old 09-21-2013, 07:57 PM
Charlie
you were the first person to run 125 MPH in a AO 3100. That was spectacular at that time.
quest is offline
Old 09-22-2013, 04:39 PM
my wedge is gone also 950 hp 32 4 blades 1.36 bravos on boxes 6700 rpm 129.6 best it will go its at the wall. how high is the x dim on that boat
Old 09-22-2013, 05:53 PM
prop shaft is 1.75 inches above bottom of sponsons.
b max drives with 1.19 ratio
33 pitch 15.5 inch diameter herring 5 blade with 1/2 inch of trim ring removed. 142 mph at 6000 rpm
x dimension too high to pick up sufficient water so I have to use offshore pickups on back of transom
slight positive trim which is 5 on mechanical indicators. tunnel tab has tapered sides to trap air when flat and is flat with top of tunnel above 115 mph.( actually 1 inch above top of tunnel but parallel with it.
hp approximately 850. single 1150 cfm dominator on 3.3 whipple charger and 10 psi boost
quest is offline
