Quote:
Originally Posted by jbbeard
I just rebuilt and repowered my boat and use both. The underhull pickups feed the engines and the low water pickups feed the supercharger chillers and also cool the outdrives by passing cold water through them. I have sea strainers attached to the underhull pickups which feed everything else. I still need to adjust the lip angle and the protrusion depth of the lip into the water stream. This needs to be done running using water pressure gauges so as to insure correct pressure at speed. This is the most tricky part when the boat goes over 100 MPH. you have to be verry careful to have enough but not too much water pressure!
These originally were installed on my boat.
http://www.cpperformance.com/detail.aspx?ID=2657
I plan to stick with them unless I can find something better.
Note to all Awesome owners. If you do have an "in hull" design water pickup, it would be wise to remove it/them for inspection. I found several things that needed attention.
1) The hull was not sealed after the hole was cut for the pickup. This was also present on the transom drains too.
2) 3M #101 sealant (or similar style marine RTV sealant) was used instead of the 3M #5200
After removing mine, I found water was present within about 1/2 area of the hole. Very little sealant was present when I removed the pickups. Removed the wood portion and filled with a mix of resin/glas fill. Will re-install the pickup of choice with correct 3M #5200.
Also removed the non sealed small wood platform used for mounting the bilge pumps in the engine compartment (in each sponson just in front of the transom). Sanded and prepped the area for a resin mix to level out this area. Will mount the new pumps using 3M #5200 directly to the floor to insure that most of the water is removed from the bilge floor.
