Fixed some gremlins like the tabs and headed back out.
Found some bad stuff I could use some advise with.
First, the boat tends to do what I would call blowing out and I think the prop that came on the boat may be way off. My tach isn't working. It is one of the things I trouble shooted today so I can't give rpm numbers. Apparently my msd is not compatible with the fariah tach so I need some type of adapter.....anyways, tell ya what I can, I did have my handheld gps so I do know speeds. First, I'm at about 3/4 throttle at 36-40 mph. rpms sound like they're getting up there. From that speed any more throttle and the prop loses traction, rpms fly, and the boat loses speed. Also, brisk throttle at lower speeds can have a tendancy to blow it out as well. When it does blow out I literally have to back down almost off plane for it to grab again. I have tried various trim and tab settings and it cured nothing. The boat has the prop that I bought with it. It is a 25p trophy plus. I'm hoping this is the problem to the terrible speed and the prop blowing out. You guys would know better than I, I'm anxious to hear what you guys think....I'm hoping it's not going to trace back to some other much larger problem.
OF NOTE: Ateco engines just rebuilt the engine, runs great....he thinks it's making 550-600 horse. The boat has a bravo with a 1.5 ratio and a 3 inch spacer added to the lower.
The second problem is equally disturbing. The steering has ALOT of slop. It's kinda like riding a bucking bronco.....well not that bad but you get the idea. It absolutely will not hold a line and will weave quite a bit. It would definately be dangerous at higher speeds. The boat is full hydraulic to the wheel. Though I have no experience with boats I'm very handy with vehicles in general and am learning as I go here. My instinct tells me air in the line and to bleed it. Is this the issue? Can you bleed these?
Also curious. I took of the covers underdeck that seperate the front of the cabin and the very very front of the boat under the tip of the sponsons. I coudln't believe it. I found three heavy sandbags up there in each sponson for a total of six. I didn't remove em but man..... the boat is not the best planing in the first place. I can't imagine without them there?!?! You guys do this? Is it normal?
Thank you so much for all any help guys. I'm new into the boating world and my prop knowledge from my other boat doesn't help because it has an arneson. I'm really reall hoping you guys tell me this blowing out and speed issue is due to the prop being waaaaayyyyy off.
