On Baja's which is better--in or out ??
Re: On Baja's which is better--in or out ??
Well the weather here still is to cold to take mine out yet so don't feel bad about not having a boat to use. I have one and still can't use it. I started the engines the other day and discovered one of the sea pump water impellers was bad so I'm replacing both of them. If it ever gets warm enough around here to use it at leasst it will be good to go by then !
Well Went Out Today And Turned The Props In (27 Hydro's) The Boat Planed Better And Rode Better
I Could Get The Nose Up Better To.
Registered User
Just an update. I had my 320 out this weekend with the props turning in. It was HORRIBLE. I will be turning them out form now on. It was hard to get it to settle in to a nice level run. Porpoised alot, could not use hardly any trim. It wasn't any faster either since I couldn't air it out like I can with them turning out. I actually had to use my tabs on very smooth water just to keep it from bouncing.
Originally Posted by BajaRunner
so whats the consensus on a 29 outlaw, in or out?
The poor handling far outweighed
the less than 1 mph gain from
running them "in"
Charter Member #1171
Out for all around good use,,,,,,,, in may get a mph or two more,,,, but poor handling.
I want to live in a world where a chicken can cross the road and not have its motives questioned.
I know this wouldn't change the handling around the dock, but has anyone thought about the toe-in toe-out differences when changing prop rotation and the way it effects cruising, top speed performance?
WITH THE PROPS IN !!!!!! I DON'T HAVE A PROBLEM AROUND
THE DOCKS MY OLD 32 CALIBER HAD THE PROPS IN TO
