How long is 30' Outlaw with the trailer?
Aluminum bolt-together trailers are typically longer than welded steel or welded aluminum trailers.
Surge brakes adds about 1' foot to overall length due to the coupler.
ITS drives or stand off boxes will add to that, as much as 12 inches.
You should be OK. If not, you may be able to cheat a little by sliding up on the trailer, or perhaps upgrading to EoH brakes and shortening the tongue a bit.
A neighbor had a special trailer built so he could fit is 30 Outlaw in his garage, which was 34-ish feet I believe. It had a really short tongue to where the bow was pretty much over the trailer jack/foot.
I had mine on a Heritage triple axle in a 39.5' inside depth, with a little under 3' to spare if Im not mistaken. With 37' , i think it will be very close and with any luck, 6" max to spare. Not sure of how a different trailer might impact the dimensions. Good luck! The 30 was a great boat!
