What happened to this motor?
Re: What happened to this motor?
Originally Posted by duksrule
What sucks is that the guy I bought the boat from just had them replaces about 5 hours ago. Wonder if they messed up the install. Anyway, I guess I should stop looking for a simple answer and get the motor pulled out. Is this about all there is to pulling it?
-Pull the outdrive
-Disconnect the exhaust and wiring
-2 bolts at mid engine mounts and 2 on the back of the motor?
-Pull the outdrive
disconnect P/S lines
Throttle cable
Shift bracket
Fuel line
Inspect the exhaust bellows and shutters in the Y pipe,
...they probably got fried.
-Pull the outdrive
-Pull the outdrive
Did the audio alarm go off ?
It should when engine is OVERHEATING,
oil pressure is low, or drive oil reservior is low.
Registered User
I don't think that it was ever ran dry.
Is there a way to wire up some sort of safety to make the engine shut down at a certain temp? Sort of like a low oil pressure shutoff but with the temp?
Originally Posted by BajaRunner
They can burn up very easily without water. Ive heard starting your engines dry and running them for 15 seconds will eat an impellor.
Registered User
No alarm that I heard.
ice bag, or some kind of other floating debris.
Gets caught on a lower, disrupts water flow
to the inlets, frys the impeller, overheats
the engine.
It's happened to me before.
Registered User
My water pickups are mounted to the transom. I can see how this can happen though. I would think that even if it overheated that it wouldn't take out a bearing with it. That is why I thought that it was the oil pump.
bford1
15
10-08-2008 12:20 PM
