Need some info
Registered User
Re: Need some info
Originally Posted by Steel Outlawed
Make sure you have a strainer if you are going to pick up the water from the outside, and a shut off valve. The toilet has one switch only it draws water and flushes at the same time.
Shouldn't the bowl be filled with water before use for some things? Or is there a different switch to fill the bowl?
Re: Need some info
My thru hull is on the transom. We just put a brass thru hull below the water line which is just below the hydraulic steering. You do have to buy the extra long thru hull though.
I would install a filter, I bet they did not install one with the porta pottie.
I would not tee into the a/c because it could starve the a/c when flushing the toilet.
I have one button, you push it and it rinses and pulls the waste out at the same time.
gacrew
04-24-2002 08:38 PM
