They came in all sizes, but always had a lot of style.
1999 Baja Sidewinder
Length 19'2" - 5.84 m
Beam 7'11" - 2.41 m
Weight 2,900 lb - 1,315.0 kg
Draft 33" - 83.82 cm
Deadrise at Transom 20°
Fuel Capacity 40 gal - 151.4 L
Passenger Capacity 6
http://www.bajamarine.com/archive/19...der_specs.html
Steering
Custom Steering Wheel
- Black w/Polished Spokes
Power Steering
Prop
MerCruiser Recommended AL Prop
Engine Compartment
Auto Bilge Pump (1 - 450 gph)
Battery Tray
Blower (1)
Garboard Transom Drain Plug
Mercathode (Std on 5.7L -
5.7L EFI Eng Opt)
SS Hose Clamps
Thru Hub Exhaust
Thru-Bolted AL Motor Mounts
Construction
End Grain Balsa Core Construction
- Below Waterline
Hand-Laid CM3610 Knit Laminates
Plexus Bonding
Plywood Interlocking Grid Stringer System
- Fully Encapsulated
Vinylester Resin Barrier Coat
Maxguard Premium Gelcoat
Electrical
Accessory Panel & Fuse Box
12V Receptacle
Full Instrumentation w/Custom Faria Gauges
- Backlit Red
Hour Meter - Integrated
into Tachometer
Horn - Flush Mounted
Courtesy Lights - Cockpit (2)
Navigational Lights
Safety Switch w/Lanyard Exterior Accessories
Cleats - Bar (3) 4"
Cup Holders - 3 Jumbo
Fully Integrated Fiberglass
Cockpit Liner
Fuel Tank w/Electric Gauge
- 40 Gal
Glove Box
Grab Bars - 3
Insulated Ice Chest - 25 Qt
Ladder Swing-Down - 3 Step SS
Fiberglass Motor Lid
w/Padded Surface
Molded Fiberglass Seat Bases w/Footrests
Molded Swim Platform w/Custom Baja Textured Surface
Custom Vents (2)
Portside Helm Station
Rubrail - White Vinyl
Ski Tow - SS (Thru-Bolted)
Side Storage Compartments (Cockpit) (2)
Storage Under Rear Seat
(Cockpit) - Hinged
SS Bow & Stern Eyes (Thru-Bolted)
SS Fasteners Thru-Out
Fuel Fill
Throttle and Shift - Center Console
Vinyl Upholstery - 32 Oz (Expanded)
Windscreen (2) - Plexiglas
Interior Accessories
Lined Bow Area
Forward Storage Seating
AL Seat Swivel - Passenger
AL Seat Sliders - Passenger & Driver
Bucket Seats w/Rear Bench - Rotocast
Stereo System
Clarion Thunder System
Stereo Protective Housing
Graphics
Wave A - 4 Color In-Gel Graphics
Exhaust
Thru Hull w/Flappers
Thru Hull w/Silencer Tips
Thru Hull w/Corsa Quick & Quiet II
Capt Call (Elect)
Corsa Quick & Quiet Plus
Steering
- Black w/Red Grips
- Black w/Plum Grips
- Black w/Teal Grips
- Black w/Grey Leather Grips
Tilt Helm
Prop
MerCruiser Recommended SS Prop (Exchange)
Trim Tabs
Trim Tabs
Engine Compartment
Fire Extinguishing System Electrical
Depth Finder - Lowrance
Carpet Cockpit Lay-In
Rubrail - White w/SS Insert
Stereo Systems
Clarion Quake System
Amplifier - 300 Watts
(on Quake System Only)
Remote Control
Graphics
Wave A (Optional Combinations)
Wave B
Boss
Full Color
Gel Engine Compartment
Canvas
Bimini Top w/Boot - Sunbrella
Sunbrella Cover - Cockpit
Sunbrella Cover - Mooring Engines
MerCruiser 4.3L / Alpha I / AL Props / 190 HP
MerCruiser 4.3L EFI / Alpha I / AL Props / 210 HP
MerCruiser 5.0L / Alpha I / AL Props / 220 HP
MerCruiser 5.7L / Alpha I / AL Props / 250 HP
MerCruiser 5.7L EFI / Alpha I / AL Props / 260 HP
