Oil temp??? >
Oil temp???
Oil temp???
Old 11-28-2006, 11:40 AM
Never Enuff
Default Re: Oil temp???
Checked with Merc and they said they did not have any specs on the oil temp. I guess i'll check to make sure the gauges are hooked up correctly and go from there. Merc said they do not install oil temp sensors on their engines????
never enuff is offline
Old 11-28-2006, 12:04 PM
The black motors don't have an oil cooler
thermostat, so if you're running in cold
water and not running it real hard, you
may not see much for temperature.
The blue motors do have an oil cooler
thermostat, they will divert oil from the
oil cooler 'til a certain oil temp. is reached.
I was running mine this last weekend in
40* water and was still maintaining 140*
of oil temp.
JaayTeee is offline
Old 11-28-2006, 04:03 PM
Originally Posted by never enuff
What oil temp should I expect after the engine has reached normal operating temp(about 160-180)? 496 Mags in a 30OL. Ran for a few hours on Friday and the oil temp gauges never moved off 140 on either engine.
Jay,
Mine barely move off 140 either. In the summer they move a little bit but not too much.
So how are you liking the 30? Have you gotten used to the twins yet? More importantly, have you opened her up yet to see what she can do?
Busta is offline
Old 11-28-2006, 11:55 PM
Moses's Avatar
I'm running carbed 500hp's and see about 180 on one and if I stay in it to long on the other can reach over 200. That worries me a little.
Moses is offline
Old 11-29-2006, 07:07 AM
Charter Member #34
Dock Holiday's Avatar
Don't let it worry you unless you really have a problem. Anything below 250 degrees on oil temp is okay.
Dock Holiday is offline
Old 11-29-2006, 01:41 PM
Yup...210-235 is good...250-265 after a hard run is fine as well...
dave-01 is offline
Old 11-29-2006, 03:12 PM
Never Enuff
Chris,
Was out last friday for about 4 or 5 hours. Really like the way it rides(no other boats out) and the difference between the single and twins is huge. I ran it up a couple of times and with 6 people 3/4 tank of gas and a 1/2 empty cooler it ran about 73 on the lie-o-meter. I didn't think that was to bad for the first time running it hard. I'm still practicing the docking stuff--( I think I'm going to ask Outlaw Ed to help me ). So far we reeeeeeally like the boat. I did find out the fastest thing on the boat was the gas gauge--that thing goes down faster than my first ex.
Jay
Old 11-29-2006, 04:29 PM
BajaRunner's Avatar
BajaRunner is offline
Old 11-29-2006, 08:14 PM
customtouch's Avatar
Jay[/QUOTE]
and probably cost just as much to make it move again!!!!!
customtouch is offline
Old 11-30-2006, 02:04 PM
Never Enuff
David,
You got that right--you sound like to voice of experience too
Quick Reply: Oil temp???
