Go Back   Offshoreonly.com > Owner's Forum > Baja
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 02-06-2007, 08:30 PM   #1
1980 scarab S-type
36 Outlaw wet weight
What does a 1998 36 outlaw weigh WET??? Anyone owners out there that have proven what their boats weigh full of fuel, water, waste, gear etc... My boat limit has a strict weight limit. Any input would be great.
Westcoast is offline   Reply With Quote
Old 02-06-2007, 08:32 PM   #2
1980 scarab S-type
Re: 36 Outlaw wet weight
Correction: my Boatlift has a strict weight limit
Sponsored Links
Old 02-06-2007, 08:46 PM   #3
JasonSmith's Avatar
1999 Baja 29' Outlaw
How much does your lift, lift? I would bet you need a 15k lift to get a 36 out of the water.
JasonSmith is offline   Reply With Quote
Old 02-06-2007, 09:11 PM   #4
outlawinil's Avatar
Sunsation 288 MCOB
Literature says 8300, add 1800 for full tank of fuel and whatever gear and you'd be close to maxing out a 12,000 lbs lift
outlawinil is offline   Reply With Quote
Old 02-06-2007, 09:51 PM   #5
2007 Donzi 38 ZR
Yep - I'd say you're close to 10k lbs. full of fuel and gear - 12k lift at the minimum.
cbeastwood is offline   Reply With Quote
Old 02-06-2007, 10:14 PM   #6
Got Boost ???
Smitty's Avatar
2000 Baja 36 Outlaw
I have calculated my 2000 36 outlaw at around 10,500. That is for a day at the lake with coolers, gas, water, etc.
Smitty is offline   Reply With Quote
Old 02-07-2007, 09:38 AM   #7
Charter Member #34
Dock Holiday's Avatar
Quote:
Smitty pretty much has it right on.
My Myco trailer weighs 2200 lbs per Myco. I have added a tool box to it with some gear inside.
On the scale full of fuel we weighed 12,800 lbs.
Subtract the trailer weight and it is 10,600 lbs. I bet my tool box is at least 100 lbs total.
Dock Holiday is offline   Reply With Quote
Old 02-07-2007, 12:54 PM   #8
1980 scarab S-type
Thats what I was guessing 10,500-10,600...The lift will will do 10,500 all day...Thanks for the replys
Old 02-07-2007, 01:45 PM   #9
BajaRunner's Avatar
I aint got $hit
Dock what do you think my aluminum triple weighs under my 36?
also, they figure all the 36 weights the same, but some have a/c, micro, etc. i wonder how much difference that makes.
BajaRunner is offline   Reply With Quote
Old 02-07-2007, 02:02 PM   #10
Charter Member #34
Quote:
I did not see you trailer but I would say the least would be 1500 lbs up to maybe 2500 lbs for a steel trailer.
Microwave = 20 lbs
A/C = 75 lbs
They really do not make too much of a difference.
I would say from a bare bones model to a fully equiped model would be maybe 300 lbs.
I was there when they lifted mine off the flatbed with the crane and it showed 8400 lbs on the crane scale from the factory will all options.
Trackbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
29 Outlaw weight? DTH Baja 8 02-23-2009 09:07 PM
Wet weight for a newer 32' Westcoast Sunsation 2 06-05-2007 09:37 PM
24 outlaw weight TURBOED Baja 18 04-09-2005 01:25 PM
weight on a 29 outlaw yesrej Baja 1 10-31-2004 08:08 PM
Can anybody tell me the actual weight of a 29 outlaw dloftis Baja 13 06-30-2002 12:17 PM
Search Engine Optimization by vBSEO 3.2.0
