Neutral is the top holes,( zero shaft angle, zero raise)
1" up is the middle,
2" up is the bottom holes.
I've been told that if you use the bottom holes
( highest position) you should also raise the
engine, due to severe drive shaft angles.
Every one I've worked on has been in the middle position.
