Go Back   Offshoreonly.com > Owner's Forum > Baja
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 01-13-2010, 03:23 PM   #741
Charter Member #34
Dock Holiday's Avatar
Quote:
Originally Posted by Smitty View Post
Nice !!! 4 rams for the steering !!! That is a serious setup.
Safety FIRST
I fought steering problems all last season. First thought there was air in the system, then changed the filter, checked the helm and we finally concluded that the inner liner (tube) on one of the hoses was failing and acting like a valve. Nothing worse than running 90 MPH and the steering wheel locks up!
Dock Holiday is offline   Reply With Quote
Old 01-13-2010, 03:31 PM   #742
AIR TIME's Avatar
BAJA OL 650HP/ SABER 28 Gellner unlimited with konrad ace
looks good doc, I am waiting for my motor hope to see it in 4weeks, and then the fab work starts on the saber and most likely the 24ol unless I sale it as is. art
AIR TIME is offline   Reply With Quote
Sponsored Links
Old 01-13-2010, 03:54 PM   #743
Charter Member #34
Quote:
Glad to hear it Art. I know you are ready to get back on the water. Good luck with the projects and keep us posted.
P.S. Have you posted any pictures of the Saber?
Old 01-13-2010, 07:17 PM   #744
crayolacrazy's Avatar
33 baja
Quote:
Originally Posted by Dock Holiday View Post
2010
IMCO HD transom assemblies are mounted in boxes with steering rams.
doc those imco boxes will they raise your x or will it stay the same or what
crayolacrazy is offline   Reply With Quote
Old 01-13-2010, 08:09 PM   #745
ndaniels's Avatar
96 Superboat 24/BBC, 95 Superboat 21/BBC
Great thread dock... I've been to Kevin's before to talk about an old boat, I take it you were pleased with Kevins work? I might have a couple of holes to fill in on my 21s transom. I had no idea about Saccenti Marine. Looks like first class work...
ndaniels is offline   Reply With Quote
Old 01-13-2010, 08:20 PM   #746
2005 Outlaw SST
You won't find any better work than Kevin's. He's the man when it comes to glass and gel.
sonic69 is offline   Reply With Quote
Old 01-13-2010, 08:50 PM   #747
www.bajaboatowners.com
Ebay Ed's Avatar
1998 Baja Boss 272 HP 500 EFI
he done some small repairs on my boat and looking at the pictures it looks pretty nice
Ebay Ed is offline   Reply With Quote
Old 01-13-2010, 08:52 PM   #748
Charter Member #34
Quote:
I have met some really good fiberglass people but never anyone as good as Kevin. He knows his stuff, he shoots straight, he gives you what you pay for and does not cut corners and he does it when promised. He has done all my work faster than anyone I have ever used before. You will not be disappointed.
Old 01-13-2010, 08:59 PM   #749
Charter Member #34
Quote:
Bobby,
Adam did a lot of calculations and when all said and done we will be 1-11/16 inch higher overall at the prop shaft.
The Baja transom is at a different angle than all other brands. I do not remember that angle off the top of my head. The IMCO boxes are really built for the other angle. They are a neutral box and the SCX lowers only come 2 inch shorter than stock.
So the bottom line is while I did not raise the "X" by raising the engines I will end up approximately 1-11/16" higher at the prop shaft.
The big question for the expert you are is "CG". You and I have talked about this a lot and you know that my 36 is a lot diffferent than the 33 in that I don't see a difference by just adding people to the back seat. Any predictions on what this setup will do?
Doc
Old 01-13-2010, 09:05 PM   #750
Charter Member #34
Quote:
Originally Posted by Sport 280 View Post
Doc, looks great, are the twins getting a little refresh? You keep going and you will have to design a 100 mph club sticker.
Fred
Hey Fred,
How you been doing buddy?
All is good with the twins. We only have 14 hours on them and they have run flawlessly. Adam has pulled the oil pans on both and found why we were having oil leaks and with the help of Mark Boos those issues are resolved and I'm confident we will not have to deal with that again.
If these drives do as promised and we don't go backwards with the boxes we have have to push the boost up and see if we can be one of the very few 36's in triple digits. I don't think we will have enough but you never know.
Take care
Doc
Trackbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Baja Will what is .... WOTW2E Baja 8 10-03-2008 08:28 PM
Rebirth Of A 42 Poker Run monstaaa Fountain 56 04-29-2006 06:46 AM
PQ vs Baja Lucky Powerquest 43 11-20-2005 04:02 PM
Baja 27 PPlay33 Powerplay 4 09-17-2005 08:45 PM
BAJA where are you big poppa pump Baja 10 02-08-2003 08:45 AM
Search Engine Optimization by vBSEO 3.2.0
