Go Back   Offshoreonly.com > Owner's Forum > Baja
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 01-13-2010, 09:13 PM   #751
Baja 342 Raylar HO 600's
Quote:
Originally Posted by Dock Holiday View Post
Bobby,
Adam did a lot of calculations and when all said and done we will be 1-11/16 inch higher overall at the prop shaft.
The Baja transom is at a different angle than all other brands. I do not remember that angle off the top of my head. The IMCO boxes are really built for the other angle. They are a neutral box and the SCX lowers only come 2 inch shorter than stock.
So the bottom line is while I did not raise the "X" by raising the engines I will end up approximately 1-11/16" higher at the prop shaft.
The big question for the expert you are is "CG". You and I have talked about this a lot and you know that my 36 is a lot diffferent than the 33 in that I don't see a difference by just adding people to the back seat. Any predictions on what this setup will do?
Doc
I thought you could get the SCX in -3?
Keith Atlanta is offline   Reply With Quote
Old 01-13-2010, 09:24 PM   #752
ndaniels's Avatar
96 Superboat 24/BBC, 95 Superboat 21/BBC
Quote:
The SC can be had in -3, SCX -2 only...
ndaniels is offline   Reply With Quote
Sponsored Links
Old 01-14-2010, 08:20 AM   #753
Charter Member #34
Dock Holiday's Avatar
Quote:
That is correct. I can only assume it is because of the larger internals. Larger gears, bearings, shafts, oil capacity, cooling passages, etc. Probably limits just how compact they can make them.
Dock Holiday is offline   Reply With Quote
Old 01-15-2010, 12:09 PM   #754
Charter Member #34
Hey Greg you think you and Adam can handle this?
Old 01-15-2010, 12:34 PM   #755
Bilge Rat
TEAMBAJA's Avatar
1996 VYPER
Are you kidding? We love drilling holes in expensive boats! Bring it on!
TEAMBAJA is offline   Reply With Quote
Old 01-15-2010, 02:05 PM   #756
www.bajaboatowners.com
Ebay Ed's Avatar
1998 Baja Boss 272 HP 500 EFI
wow they are proud of those things arent $1100.00 each i just about crapped
Ebay Ed is offline   Reply With Quote
Old 01-15-2010, 02:15 PM   #757
Charter Member #34
Quote:
You can buy them several hundred dollars cheaper$$$$$ than the MSRP.
Do some shopping. I got a really good deal on eBay.
I've seen these on some high dollar yachts and they are fantastic.
I will not be running the light except when parked at dock when we can enjoy it.
Old 01-15-2010, 02:55 PM   #758
Ebay Ed's Avatar
i looked on ebay didnt see any doesnt matter anyways i cant afford them right now any way XT has all of my money LOL
Old 01-15-2010, 04:00 PM   #759
Charter Member #34
If you watch they pop up from time to time. I missed one a few weeks ago that was cheaper than I paid. There is also a deal out in California that had this unit under $800.00 with free shipping that I found searching the web. You just have to shop around. Are they expensive, YEAH but having seen one in operation I think they are worth it. I was also lucky to find the blue color which was my first choice.
Old 01-15-2010, 04:57 PM   #760
2005 Outlaw SST
Doc, Adam is putting a set on my boat now. They aren't as high dollar as yours, but I think they will get the job done. He's also doing some led's. That's your fault for posting the pics of yours. I'll let the wife know were to direct her anger for the money spent towards you.
sonic69 is offline   Reply With Quote
Trackbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Baja Will what is .... WOTW2E Baja 8 10-03-2008 08:28 PM
Rebirth Of A 42 Poker Run monstaaa Fountain 56 04-29-2006 06:46 AM
PQ vs Baja Lucky Powerquest 43 11-20-2005 04:02 PM
Baja 27 PPlay33 Powerplay 4 09-17-2005 08:45 PM
BAJA where are you big poppa pump Baja 10 02-08-2003 08:45 AM
Search Engine Optimization by vBSEO 3.2.0
