| OSO Sponsor |
| OSO Sponsor |
02-08-2009, 11:43 PM
#31
86 Baja 320 Force
Looks like fun!
glad I am done with that part of my boat...
86 Baja 320 Force
02-10-2009, 07:47 AM
#32
That is a tedious project to say the least. Question for you. Why not focus on the section that includes all the rot and another 6" of good wood to be sure and then glass it back up? I ask this question because I have seen several posts where the x-dimension was changed or a drive was changed and the patch to the transom was never very large. I read somewhere that you want to overlap the plywood 6 times it's thickness, so if you are using 3/4" ply then make your joint overlap 4 1/2" outside the hole that you are trying to cover.
02-10-2009, 09:50 AM
#33
Just a squirrel...
88 240 with a new lease on life
Quote:
I thought about that, problem I've been coming across is that on the surface the wood will look ok. Then I'll pop a piece off and find wet wood/rot underneath. Believe me I would like to be able to leave the good half on there but in the end I think it will be easier to just pull it all off and then start from the outer skin in with full sheets. It's coming along, I just need to quit partying so hard on Saturday night so I can get something accomplished on Sunday...
02-10-2009, 02:07 PM
#34
Baja 25 Outlaw
You slacker, I can't believe you aren't done yet!
Been busy getting the rental ready to rent. Give me a call if your out there this weekend. I'll stop by and bug you
Looks good and like alot of work!
02-10-2009, 05:25 PM
#35
BAJA OL 650HP/ SABER 28 Gellner unlimited with konrad ace
looks good the snow has melted a little, I hope my transoms good, I know the side shelfs are chit I fixed one in a hurry  so it did last more than 2 yrs. the rails suck cause water can get in spread like in the hatches and thats all balsa  .
02-11-2009, 08:52 PM
#36
Oh I may have to shorten my gas tank, do you know how much room there was from the gas tank to the rear bulkhead was it a 1'' or a few , cause for us to put the blower in I need to move about 8'' wide of bulkhead back to pick up a couple of inches, I have seen it done on other boats just one 24ol which was for sale in the class under baja they had a 1471 blower motor out of penn I think and it was a 93 or 94. I tried to bend my knee to kneel on it  no way, Iwas out lineing my stainless marine exhaust on card board to send to illos so they can see if they will work on a fountain 27, mine are dry and were made 4'' higher than stock so my tails are always out of the water so the transom won't have water trying to soak in. I resin my everyother yr and glue silicone on top of that so the pipes and gasket won't let water in. so you should change yours if you can.
02-15-2009, 11:38 PM
#37
Just a squirrel...
Quote:
I'll check next weekend. From what I remember there was about 1 inch in front of the tank and 1 inch behind. I'm going to move the rear bulkhead forward a little bit, I haven't decided how much yet. At least two, maybe 4 inches.
02-15-2009, 11:42 PM
#38
Just a squirrel...
At it again, there was two layers of half inch and one layer of 3/8 inch and about a quarter inch of 'goop' between the skin and the first layer of ply. Looks like resin and low density filler used to bed the wood to the skin. I was a little disappointed that the skin was only about 3/16 of an inch thick, but I'll take care of that with a few layers of biax once I grind/chisel all the good off.
Second layer gone, only one layer left!
02-15-2009, 11:45 PM
#39
Just a squirrel...
Looking long and hard and wondering if I should just get out the chainsaw...
02-15-2009, 11:47 PM
#40
Just a squirrel...
Got some sense back and went back to work. Got the last layer out, all that's left is to chip away/grind out the bedding and the rebuilding can begin. Finally have to put in a glass order
