Go Back   Offshoreonly.com > Owner's Forum > Baja
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 03-04-2010, 11:00 AM   #81
Baja 25 Outlaw
Looks good! I have been meaning to call you and see what you have been up too
danh63 is offline   Reply With Quote
Old 04-25-2010, 01:45 AM   #82
Just a squirrel...
c_deezy's Avatar
88 240 with a new lease on life
Still at it...adding ribs between inner and outer stringers. I added one more after this pic, for a total of four under the cockpit floor on 18" centers, with the last one at 12" to bulkhead the fuel fill hoses.
c_deezy is offline   Reply With Quote
Sponsored Links
Old 04-25-2010, 01:47 AM   #83
Just a squirrel...
c_deezy's Avatar
Floors are in...roughing in bulkhead to go all around the hull and support the deck.
Old 04-25-2010, 01:49 AM   #84
Just a squirrel...
c_deezy's Avatar
Doubling up the balsa where the full hoop bulkhead will go. Vacuum bagged, should be ready to do the bulkhead when I wake up today.
Old 04-25-2010, 11:18 AM   #85
Baja 25 Outlaw
Damn that looks good
Old 04-25-2010, 05:24 PM   #86
Baja 33 Outlaw
Nice looking work!
pwam1 is offline   Reply With Quote
Old 04-25-2010, 09:24 PM   #87
Just a squirrel...
c_deezy's Avatar
Thanks for the comments. If I had put it back together the way it was, then I'd probably be done with it. But decided to change things around, add some seats in the cabin and an extra bulhead. All of the horizontal peices will be balsa that I vac-bagged on a table to try to keep the weight down as much as possible in the cuddy. And I think I probably spent two days getting the stringers/ribs level to keep the floor level, got it to within about 1/16th of an inch on a 6 foot straight edge so I figured that was good enough.
Also made a flange all the way around the fuel tank so I dont have to screw the floor gas tank cover into the stringers. I don't want anything getting screwed into the main stringers unless it absolutely has to. Some things I'm sure I went waaay overboard on, especially for a 20 year old boat, but I figure its a good learning experience and this probably won't be the last one I rebuild so why not.
Should be a freaking tank when I'm done with it.
Old 04-28-2010, 03:44 AM   #88
Just a squirrel...
c_deezy's Avatar
Sidetracked on motor work on Sunday, fine tuned, sanded and rigged the bulkhead pieces yesterday, glassed them in tonight.
Old 04-28-2010, 03:47 AM   #89
Just a squirrel...
c_deezy's Avatar
My vacuum bagging rig. Found the kit/directions on www.veneersupplies.com, got the pump on Ebay for 60 bucks. Worked out pretty good, instead of running constantly and having to throttle the pressure, now its like a Ronco, I set it and forget it. As long as I keep the leaks to a minimum it cycled sproradically just like it is supposed to.
Old 04-28-2010, 08:17 AM   #90
looks good it will be better then new .
bajabob is offline   Reply With Quote
Trackbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
And so it begins........ Anarchy Powerboats Fiberglass and Paint 9 03-24-2007 06:23 PM
the count-down begins!!!!!! racesdad General Racing Discussion 1 01-05-2007 06:22 AM
BEAKLESS - Shopping Begins! masher44 General Boating Discussion 25 05-07-2005 10:02 PM
The project begins! Dave M Superboat 15 09-16-2004 08:09 PM
Search Engine Optimization by vBSEO 3.2.0
