Go Back   Offshoreonly.com > Owner's Forum > Baja
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 06-03-2009, 12:07 AM   #41
www.lakestclairrun.com
Irishtornado's Avatar
2003 Baja Boss 302 HP500efi's
Quote:
Originally Posted by JasonSmith View Post
If you do +3 boxes from IMCO you have to raise the engines 3" which means raising the exhaust 3" which means custom tails if you have headers.
A neutral IMCO box with -2" shorties will get you where you want to go.
Stellings with -2" IMCO lowers will give you the most flexibility & that would be the route I would take in your shoes.
So throw a set of these on with my drives and 2" shorties and I'll be roughly where I want to be.
http://newyork.craigslist.org/wch/boa/1201164013.html
Irishtornado is offline   Reply With Quote
Old 06-03-2009, 10:01 AM   #42
JaayTeee's Avatar
2002 baja 33 o/l 575sci's
Ditto.
JaayTeee is offline   Reply With Quote
Sponsored Links
Old 06-03-2009, 11:51 AM   #43
JasonSmith's Avatar
1999 Baja 29' Outlaw
Yea, for the money, that would work. The Stellings boxes on -2" drives would really be the ticket, but it is hard to turn down a deal like that......if it is legit. Craigslist + New York/New Jersey + CHEAP = 3 strikes.
JasonSmith is offline   Reply With Quote
Old 06-03-2009, 12:13 PM   #44
Baja 342 Raylar HO 600's
That should get you there since you are close to 80, the IMCO lowers might hurt you in speed but gain in handling. The IMCO lowers actually slowed my boat down a little (2MPH) but that was my boat. I had a lot of people tell me the stock lowers would work better at 80MPH and they were right. The net effect for you might be +1 or +2 MPH with boxes and lowers though.
Everybodys boat is different... You NEED to shoot for 4 inches of drive height "X Dimension" with boxes. With BBlades Baja cup Bravo 1 props you will come out of the water like a bobber. How you get there is a MONEY thing! Stellings, you can keep your lowers but you have to deal with the bearing carrier. IMCO you have to buy lowers but you end up with a bad a$$ setup.
Between all of us we still arent exactly the same Jason/Indy are over 90MPH where the IMCO lowers really help but with a VERY similar hull as you. On the other hand, my hull is a little bigger but I am in the same speed range as you.
I think you need to get this project going soon! I am in detroit June 18/19 so you better go buy those boxes so I can help you install this stuff.
Keith Atlanta is offline   Reply With Quote
Old 06-03-2009, 12:14 PM   #45
Jason/Indy - Do you have to pull the engines to put the IMCO boxes on?
Old 06-03-2009, 01:45 PM   #46
JasonSmith's Avatar
Quote:
Yes you do. Gotta change out the inner transom plate. You gotta pull them regardless of who's box you use.
Old 06-03-2009, 04:57 PM   #47
Guy emailed me back is getting more pics. They are complete kits. Neutral boxes. Sending me more pics.
Old 06-03-2009, 05:01 PM   #48
I agree. This will be a winter project. The season is too short up here to tear the boat down now. Heck your about 1.5 weeks too early to be in Detroit..Come up on June 25th and join the party.
Old 06-03-2009, 05:08 PM   #49
JasonSmith's Avatar
You need to know what size u-joints the shaft takes. 1.75's are the best ones. If the kits don't come with the driveshafts, let me know, I know a guy........
Otherwise, make sure they have the steering wings, inner transom plates, inspection plate covers, and driveshafts. You will need longer hoses for your steering rams also and exhaust y-pipe block offs & 4 tubes of 5200 to seal the boxes to the transom.
Also, get the 2(ea) short studs to replace the long ones on your existing transom assemblies.
Old 06-03-2009, 05:09 PM   #50
JasonSmith's Avatar
Oh, you'll want to start looking for a set of 380 k-planes too. You can buy just the lower plates. I paid about $350 per plate.
Trackbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
ITS and extension boxes fastmcars General Q & A 7 11-12-2007 03:41 PM
03 42 with extension boxes Wild Cigarette 2 10-03-2005 06:43 PM
extension boxes strghtfwd Cigarette 22 12-30-2004 05:16 PM
Extension Boxes Zanie General Q & A 13 11-11-2004 10:32 AM
Stelling Boxes on my Formula 302 Audiofn General Q & A 12 11-14-2002 09:52 AM
Search Engine Optimization by vBSEO 3.2.0
