aftermarket swim ladder
Custom Interiors & More
The spacing for the Tubes matched up perfectly to the ladder holes so all I did was pull the black rubber piece out (easy to take out and put back in) drilled thru. the tube for 3/8" holes then counter drilled the top of the holes for socket head cap screws. Then used nylon lock nuts on the bottom side and put the black strips in. Done
XT
Kilroy,
I ordered the ladder you suggested. I should have it in the next few days. I plan on installing it sometime next week. Thanks again for the info. I will let you know how it turned out.
Walt
Walt
Kilroy,
Just letting you know that I installed the swim ladder last evening. Looks great. Can't wait until I use it this weekend. Thanks again for your input and everyone elses. Much appreciated guys.
Walt
Walt
Hey Mike. The swim step looks great! From the photos it looks like you're on the water. Did you get the boat done?
I haven't got the new step on mine yet. I have to drill new holes and plug old ones so I may wait until this winter to do it. I want to go external steering too so may do it at the same time.
Going to be in Dana Point this weekend and run to Long Beach for lunch on Saturday if you're interested in meeting up.
-Al
-Al
Mike wrote:
Hello there, finally got the boat going. It runs strong and looks good. I was going to hook up with you, but the family wanted to go a long with another family, so we ended up at the lake. Next two weekends i will overseas, but once i get back, i will get a hold of you and get together for Catalina run, if interested.
-Al
-Al
