Go Back   Offshoreonly.com > Owner's Forum > Baja
Register Upgrade/Renew Membership Forum Rules Search Today's Posts Mark Forums Read
OSO Sponsor
NorTech
OSO Sponsor
NorTech
Advertiser
Advertiser
Thread Tools Search this Thread
Old 10-12-2009, 03:57 PM   #1
Lift Size for 38 Special
According to the specs the dry weight for a 38 Special is 9500 but with fuel and gear I am wondering if my 12,000 lift would be big enough. Any thoughts??
knotbad is offline   Reply With Quote
Old 10-12-2009, 05:58 PM   #2
Faja 38 Special,29 Four Winns Cruser,11' Boston Whaler,.. Faja 40 Outlaw
knotbad,
I weighted my a few years ago...full tank of gas, water tanks full, coolers,tools and everything we always have on board.This is with an aluninum trailer, so I would say 12000lbs lift would be fine.
Tom & Marianella
"The Wet Spot"
boatman22 is offline   Reply With Quote
Sponsored Links
Old 10-12-2009, 06:02 PM   #3
370ss
Get a 14,000#. They seem to be more readily available. Unless you have one lined up already. Your cutting it close with a 12,000.
redbud35 is offline   Reply With Quote
Old 10-12-2009, 07:12 PM   #4
Baja 342
Do you have a cable lift or a hydrohoist type lift? If it is a cable lift you can probably go with bigger cable (call the manufacturer) it is a pretty cheap upgrade. If it is a hydrohoist or similar, You might have to put the boat away with less than a 1/2 tank every time you put her up... I had a 8K lift and it struggled with my 30, then I got a 342 and it left the belly in the water so I added a 12 foot tank under the middle and it worked great.
Keith Atlanta is offline   Reply With Quote
Old 10-12-2009, 07:17 PM   #5
2004 25 Oulaw SST
Quote:
The lifts are actually tested for more than there rating too, I would think you would be fine with a 12,000 but as Redbud said, a 14,000 may be easier and less expensive to find.
Baja_man is offline   Reply With Quote
Old 10-12-2009, 07:34 PM   #6
Thanks for the feedback. Sounds like the 12,000 would work, expecially with 1/2 tank of fuel, although a 14,000 would probably give me a better piece of mind.
Old 10-12-2009, 07:51 PM   #7
Baja 442
When I had my 38, I had a cable break on my 12,000lb lift so I would recommend you go with the 14,000lb lift.
kr1276 is offline   Reply With Quote
Old 10-12-2009, 08:24 PM   #8
370ss
Don't know your location, but try dockrealty.com Dave has alot of lifts for sale. There are a few 14,000# for sale around $6-7000.
Old 10-12-2009, 09:20 PM   #9
Charter Member #1171
2000 36 OUTLAW
12k min,,,,,, 14k is preferable,,,,,,plus that gives you room to upgrade !!!
ARTIFICIAL INTELLIGENCE IS NO MATCH FOR NATURAL STUPIDITY !!!!
obnoxus is offline   Reply With Quote
Search this Thread:
Advanced Search
vB code is On
Trackbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0
Copyright 2008 OffShoreOnly. All rights reserved.
