Go Back   Offshoreonly.com > Owner's Forum > Baja
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 10-15-2009, 03:08 PM   #11
JasonSmith's Avatar
1999 Baja 29' Outlaw
Quote:
Originally Posted by XT-Innovator View Post
All the singles that Baja Marine put together were "too low" on the "x". That includes both the 25 OL, and the last 26 OL that was at the 2007 Dealer Meeting. It had no speed advantage, and the handling was poor. Lesson learned.
XT
I never understood why that was done. When a model is designed, what makes the determination as to where the x is placed?
After a plug is made, does the plug get tested before it is a mold?
JasonSmith is offline   Reply With Quote
Old 10-15-2009, 03:32 PM   #12
Custom Interiors & More
XT-Innovator's Avatar
7-Bajas, all gone!
No, our plugs were a solid block of foam that was cut on a 5-axis router at Sea Ray, and send to Bucyrus for us to put the finish on it, to the create the hull mold. Most smaller companies do a plywood plug, over cross sections by hand in comparison.
Testing was done on the first "prototype" boat that was produced, and we started by cutting a real high "x" and installing outdrives that had spacers installed. We usually decided on the best height after much testing, and handling won many times over any small speed gain. The 23, 26, 30, & 35 prototypes all ran good right out of the box without any real modifications.
XT
XT-Innovator is offline   Reply With Quote
Sponsored Links
Old 10-15-2009, 09:20 PM   #13
baja 2002 25 outlaw
Thanks JT, I was giving it all she had she didn't have anymore. I think I have reached my limit with my stock power. The only way I am going to keep up with twins is more power!
violator is offline   Reply With Quote
Old 10-15-2009, 09:23 PM   #14
www.bajaboatowner.com
2002 33OL
Quote:
Just buy a boat with Twins.
Will
Anchorman is offline   Reply With Quote
Old 10-15-2009, 09:57 PM   #15
www.lakestclairrun.com
Irishtornado's Avatar
2003 Baja Boss 302 HP500efi's
I could see you in a 33OL with boxes...
Irishtornado is offline   Reply With Quote
Old 10-15-2009, 11:24 PM   #16
Nightlife1970's Avatar
1988 Baja 280 Force
Here is a video of Steve boat running. He is the second boat to go by.
http://www.youtube.com/watch?v=P4I9aNm9uSY
Nightlife1970 is offline   Reply With Quote
Old 10-16-2009, 12:40 AM   #17
AIR TIME's Avatar
BAJA OL 650HP/ SABER 28 Gellner unlimited with konrad ace
Thumbs up
I picked up 4 or 5 mph 83.2gps with my 2'' shortie better handling flew flat across swells, also THE GUY FROM GERMANY who had the 25ol 525 put a 3 raised box on his boat he hit 81gps, then last year put a merc 600 plus a 2'' shiortie ended up lowering it 1'' and the last I talked to him he was at 87 or 88 and climbing. with the shortie you need a 4 blade or 5. I always use my k planes when I come up on plane anyway less stress on the all the boat parts. hope that helps.
AIR TIME is offline   Reply With Quote
Old 10-16-2009, 03:38 AM   #18
2006 Baja 25 Outlaw/Soon to Have 2006 Active Thunder Savage
Quote:
Are you saying you gained 4 to 5 mph with just adding a 2" shortie? If so which one did you use? Thanks.
dennis1009 is offline   Reply With Quote
Old 10-16-2009, 08:16 AM   #19
2002 33OL
Quote:
If you look at his speed he put in bigger power first.
Old 10-16-2009, 10:36 AM   #20
JaayTeee's Avatar
2002 baja 33 o/l 575sci's
Quote:
I could too.....I know where one is......but, he would
have to re-do that fancy picture on the back window
of his truck though
JaayTeee is offline   Reply With Quote
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
