Sticky Tape on Swim Platform
Busta, I think you will find that they didnt use 5200 on it or at least I hope they didnt. Mine had either 4200 or White silicone in the holes. I had 3 or four through bolts on the top and 2 lag bolts on each down leg. Loosened them and off it came. Same with my 25 when I took it off. I took a few pics of mine but they didnt come out. I got a 3-4 color powder coat that is bad a$$. move the sun and the color changes. pics dont do it justice. You will need someone to help you as they are a little heavy.
I got a roll of that tape from extrem they gave
me a small can of glue to put on first. If you dont
use the glue the tape will come off. Get ahold off
Brian 41 he should have the tape for olot less ,
Rick
make sure you use the glue
Rick
I dont remember the name its down at my home in Fla,
I think its made by 3m its yellow real tacky and strong smelling
When I get down to fla I will post the name of it.If you need it
sooner call extreme marine in twinnsburg ohio, they have
a webb sight.
a webb sight.
If it's is yellow and made by 3M, then it is their trim adhesive. An automotive paint store should have it, or a NAPA store.
