Bilge filling with water?
Sometimes, when theres a leak, there will
be a hard water stain that develops where
the water runs along....you can look for the stains
on hoses, etc.
The last time I had to track down a leak, I had to
take out the seat back, and have a friend drive the
boat while I looked for the leak......he had to run it
90 mph before I could find something....it was
a inlet hose from the thru hull pickup.
on hoses, etc.
OK guys, I dont think its the oil cool. I climbed all over both of them and there is no sign of water or stains.
What else could this be?
Boat has to be moving in order to get water inside....Speedometer tube or fittings on the transom asseembly where the tube would connect to? But not sure about thr amount of water you are talking about unless both sides are unhooked.
That might work. I was even thinking about taking the hose off the "out" side of the seawater pump and hooking it to a garden hose.
But does a regular home style garden hose have enough pressure?
Try hooking a hose to the water pick up for
the speedo, I see you have a gps but the pick
up steel has water going in the hose to where they
plug it. The seams on the hose usually crack.
hopefully thats it, cheap fix if it is.
