Exhaust pipe swap >
Exhaust pipe swap
Exhaust pipe swap
Old 07-01-2010, 11:04 PM
mpally's Avatar
Originally Posted by PDubs
Thanks for the test-run follow-up. Question though, how do you prevent water from coming into and up through the pipes while anchored? At one cover where I anchored, it wasn't totally clear of the channel and every now and again some stray wake would find itself trying to go back up the pipes.
Are there any flaps or protection on the pipes that you installed?
Yes, there are internal flaps to prevent reversion.
mpally is offline
Old 07-01-2010, 11:07 PM
mpally's Avatar
[QUOTE=mittens;3149320]mine look like this ont he out side
Mine has the full pipe (big hole )and you can see the butter fly flappes on the inside.
the picture below has the same outer flaps, but the picture where the flap is open, it has has a smaller hole, mine does NOT look like that. that is a muffled tip, DID YOURS LOOK LIKE THIS OR NOT? mpally?[QUOTE]
Our old tips looked liked the one in the bottom right in your picture, but I think there is an additional set of mufflers on the inside. You can't see through the old tips. I can post a picture of the old tips next week when we are back at the lake.
mpally is offline
Old 07-01-2010, 11:08 PM
mpally's Avatar
Originally Posted by mittens
mpally,
Correct me if i am wrong, did we decide if we had the same stock set up? corsa captins call, with out mufflers stock?
and all you did was swap tips and now you can tell a big difference?
Yes, all we did was have the tips swapped out, not other changes.
mpally is offline
Old 07-08-2010, 09:25 AM
but did you have mufflers in you tips? or just the stait through stock tips?
sorry to be suck a pain just want to be clear.
mittens is offline
Old 07-09-2010, 07:14 PM
mpally's Avatar
There were mufflers in there.
mpally is offline
Old 07-12-2010, 09:22 AM
OK thats what i though. i gott o find someonen that had mine and then swapped
mittens is offline
Old 07-12-2010, 02:53 PM
I've used the Hardin Marine angle tips with the internal flapper. It's their new design that doesn't make any noise. I hated them. The use a waffle type back plate which I feel restricted my exhaust AND changed how it sounded. Maybe not on a stock engine or switching from mufflers would it make a difference. The other thing is that the rubber gets blown back and will eventually stay that way. I was always nervous that if water went up the tip they wouldn't shut flat. The tip itself is nice. Just hated the flap design.
I would go with the Dana peices and if the flaps ever do burn out you can replace them without removing tip.
steveh1209 is offline
