stringer drains
while prepping my engine bay for my engines on my 97 322 i noticed the drains located at the end of the stringers where it meets the transom look to be nothing more then just holes drilled thru. I cant feel any glass on the top and 3 of the for have pockets which are full of crud. (ive pulled out the crud and everything is rock hard behind it)
is this normal practice for drains? im thinking of using 1" pvc pipe covered in 5200 to seal it up just the thought of water sloshing around in the summer then freezing in the winter is driving me nuts and now is the time to do something any thoughts? |
Mine were the same way on a smaller 232, i filled the pockets in with some resin. and coated anything that looked like it need sealing.
Originally Posted by steveh1209
(Post 3436771)
I installed drains in my 24 ol and i used pvc like u said but used resin to seal them in.
i ended up using 1 1/4" pvc pipe and the 5200 that size of pipe worked perfectly. it only took minor grinding to fit it
We are rerigging the race boat and what I did was fill in the old holes with wooden dowls coated with resign. Then went to west marine and got 2 of the brass thru holes they sell for bilge drains and seals around them with 4200.
