I love my Baja, but.......
#31
i think alot of my problems was caused by neglect maybe sitting outside uncovered but there was some stuff that Baja did to it that wasnt done right that possibly could have prevented some of the issues if it would have been done correctly
www.bajaboatowners.com
#32
yea the stringers by the fuel tank you couldnt get to the back side because of the floorso it had to be split in half like that so i am redoing the cuddy area while it is apart new seats, carpet and headliner along with all of the stringers and bed wood up there going to have a brand new 1998 when it is done and probably will be stronger better built and look better than when it was new in 1998
#33
Well, my hat's off to you Ed. That's the biggest refurbishment I've ever seen. Keep this thread up to date, I'm sure we'd all like to see your progress! What's your best guess to have her back on the water?
For your new interior, did you go custom, or original colors?
#34
actually c deezy redone an older baja and done about the samething if not more to his as for the cuddy putting the same color white headliner in it i have no idea what the seats look like ( if they used the same colors of my cockpit interior they will have dark blue, yellow, silver carbon fiber and white ) maybe XT will post some pictures of those and replacing the gray carpet with a blue i should probably just start a new thread on my boat i didnt mean to hijack Laniers post
#35
Not to be a prick, but what does something like this cost? i would think it would be cheaper to total it out, or sell it cheap and buy something else..
just curious i hope i never have to find out.
#36
i honestly cannot answer what just the repairs would have cost because i am having so much other stuff done like i said before some people tried to talk me into just scabbing it back together and dumping it and buying something else but there is nothing saying i would not have had the same issues in a couple of years with a different one this way i should not have any problems with the hull / wood for a long time i mean the screwed up way lasted 13 years done right it should last forever right ??
#37
Registered User
So if my boat has some issues like these am I safe hitting big swells? Is the hull solid fiberglass on these boats? I did noticed a crack in the right rear of the boat where someone opened the sundeck to far and I think the stringers were a little wet at some point.
#38
i never had any issues with jumping waves or anything i went to put a 500 efi in it and we found the issues and i just wanted it fixed right
#39
Ed, what caused your stringer and transom rot? I've tapped all around my transom and stringers underneath the engine, and everything is very solid. Also, why did the boat have to be split apart - access difficulties?
What's weird on my 1996 272, is water drains from the cockpit into the areas between the 2 stringers on both sides, and there's no passage or drain hole down to the bilge. Maybe that's a good thing, but water sits in there, so I ShopVac the water out when I get home so that it's not pooled there while the boat sits idle. I've even thought of using a 12v pump to make this job easier each time. The rest of the time the boat has a good full cover on it.
The trim tabs scare me (from what I've read on here) so I will completely seal them one of these days. Screws, and all edges.
Haven't pulled my fuel tank floor yet, but it's on the list....
#40
I don't know why the damn image isn't showing up...so here's a link http://www.flickr.com/photos/66572271@N03/6059529313/
