Baja by Fountain.
Custom Interiors & More
XT
My....
old 24' Sonic is a liner boat and I hate that part about it. The factory globs glue all over the inside of the hull and hope they get a good contact between liner/hull.
Both of mine pulled loose under the V berth in the bow and thats the only access place to inspect the liner/hull joint. But they save a ton on labor building them that way so........
Not that that's an important or highly loaded area or anything
I'd much rather have a traditional stringer boat. You lose a ton of interior space in a liner boat too.
The older stringer constructed Checkmates are huge inside compared to the newer/current liner style. Cockpit but especially in the cabins.
I have probably one of the last 26 Outlaws made in Ohio and it is a liner boat. Personally I really like the construction as it has a much nicer finish and is easier to keep clean IMHO. No cracks, rattles, or other issues here and there are plenty of times where I drive it like I stole it
True.
I agree with russellhorn. I really like how clean everything is and how easy it is to clean up. No cracks or rattles with mine either. Cabin is sweet and easy to clean as well. 4+ years and still smells new. Pretty sure cabin is not smaller as someone mentioned. Looks to be the same size or bigger as the older 25's with stringer system.
If engineered and constructed properly they are also plenty strong.
Many pf the cracking problems we see are from poor workmanship during assembly.
The bad is:
You cannot gain access in most instances to assure the integrity of that liner to hull bond so you have no way of knowing whats under there.
It hides everything construction wise so same as above applies.
If you have any void/breach in that seal over time and in an area where you get water, it will get under liner and never come out in most cases.
As far as space, the liner in my 24' sonic is approx. 8" away from hull on inside of cockpit. That means I'm losing 16" of bench seat length/storage area, same inside the sun lounge, same with bulkhead storage/lack there of from lounge seat to cabin bulkhead (life jackets, bumpers etc).
In the cuddy it's the same. My settee's are 8" narrower (they're against the liner walls), my vee berth is 16" narrower and about 12" shorter. This also eliminates any storage around the perimeter of the vee berth.
May not sound like a lot but it really is if you compare boat to boat and if you actually stay/weekend on the boat like we do.
By cutting into my liner I've added probably 20% storage space to my boat and it still gets packed full of crap.
In the attached picture you can see the three storage hatches I added to the vee birth and also in the liner above the vee birth.
There are one more on each side of walls not visible in picture and then the two under the settee's are orig.
Did same in sun lounge and cockpit.
