750 hp baja 25 outlaw
Whats up boyz i need some help iam having a 750 hp engine put in my 25 outlaw in spring, I need some info on what I should do with the drive setup. Do I put on shorty or ext box or both and if I should go full hydraulic steering with one ram or 2 thanks. O ya my drive now is bravo 1 with 300 tame hrs
1 Post
I'd recommend Extension Box, Dual Ram FULL hydraulic steering and a Imco SC Exreme drive you could skip the box, but your drive won't last that long and without full hydraulic steering neither will you. Not trying to be a ass just stating what I know to be facts. Your looking at speeds above 80mph.
1 Post
When setting up your boat, do one thing at the time. Dual hydraulic steering is a must though. Don't think so much about the shorty and box, spend the money on making it live to begin with, You have a timebomb on your hands, so be prepared to spend money on new drive parts. Keep spare gears, shafts ect. if you want to avoid down time. Important but often overlooked things when doing this kind of swap are.
Full dual ram hydraulic steering.
Fuel system that can feed the power without problems.
Cooling system.
Drive. (Mr. Gadgets, Max Works ect.)
Don't add both the box and shorty at the same time. Do the box and make it work, then you can try a shorty. Doing several things at once when setting up, is just a nasty can of worms.
Cooling system.
Cooling system.
Cooling system.
