Locked engine Hatch
???? Unless your actuator has been changed from the factory set up, you should be able to lift it up about 8 inches and get in there to remove the bolt that connects the lift to hatch. The hatch is very heavy. If you cannot lift it up at all, I don't know what to tell you.
