swim platform rubber insert
You can try this it is what i used on mine seemed to work great http://www.safewaytraction.com/Safet...onSlipTape.htm 3500 safe track
Custom Interiors & More
Taco was the only source that I knew of that made it.
I just put one of the old style platforms on a 220 Sport and I painted the platform with Black bedliner paint. The rubber inserts had shrunk-up but I ran a bead of black silicone in the channel, then I pushed in about 8" of rubber insert and taped it in place with Duck Tape. Then I streched it across the entire span pushing it in the wet silicone and taped it in place. Even put some sealer at the ends, and it turned out great!
XT
XT
I'm not sure how you put the stick on non-slip. Yours should have had the slot in the top for the rubber insert. Did you just apply over that slot? Did you fill the slot in first to keep water out? Any photos?
Thanks, Mike
XT
XT
So did you reuse the old rubber inserts by stretching them and holding them in place with the silicone?
HotTub
Still looking, if I cant find it, Im going to try Daves suggestion, mine just needs to be streached about 4 inches, aaahhh that didnt sound rigt.
I guess this is 4 rib ?
4 rib I guess
here's a pic
