Advice needed, Baja 29 outlaw Props.
Hello All.
Am new to this site but am sure some of you can help.
Baja 29 outlaw running Twin 350 mag mpi. (300hp each)
I am only getting 4100 Rpm with current props.
24 Bravo 1 4000 Rpm, really fast off mark no cavitation really happy but 60 Gps
25 mirarge had 4100 63mph gps very slow off mark and lots of cavitation.
I need engines to rev to 5200 there not as you can see. I have had engines plugged in and they have only been to +5200 for 3 mins must be when jumping.
I was thinking buy a set of bravo 1 22 pitch but want some advice before i buy another set of props.
What do you all think.
Thank you.
Thank you.
If I remember correctly (brain is a lil foggy from back then) the small block boats had Mirage 3 blades with 21's on them. Your operating range should be 46-4800 with those motors if stock... What year is it? Post 454 they went to a 6.2 small block....
Charter Member #1171
22's wont do it either.
Id borrow/rent a set of 20's first.
I want to live in a world where a chicken can cross the road and not have its motives questioned.
Hi The boat is a 2001. it did have 454 engines but they blew so the last owner put in 2006 350 mags. Personaly i would have put 496HO in but hey ho.
CAn you ger a 20 pitch 4 blade prop?
Yeah I need to borrow idealy.
Am in england. I have put on the sites here though so have to wait and see.
The 350 MAG MPI used to be listed at 4,600 - 5,000 RPM but at some point Merc upped that to 4,800 - 5,200 RPM. Not sure what year they made the change. I had a 2000 350 MAG and it was max 5,000 RPM.
really that small? I think I would get a lot of spin or cavitation thoush as there only 3 blades. when the 25 mirarges were on it would take a wile to get up on the plane and also if i backed off and put throttles down again it just reved up.
I was on the mercury prop calculater last night. it also came up with mirages and rev 4 and Vensura
about the 19-21 mark.
Anyone used Vesura props before? Any good??
