HELP!!! How to Remove Safe-T Steering
steering wheel / hub puller it bolts to the adapter that the steering wheel was bolted to and presses against the shaft put some pressure against it and then tap the tightening screw with a hammer should pop right off
www.bajaboatowners.com
Normally a hard whack on the end of the shaft loosens it. If not, then I normally sit on the dash facing aft, apply loads of pressure on the wheel with my thighs, whilst hitting the shaft with a hammer and centre punch. Try to not miss the shaft though, as it makes your eyes water!!!!!
