Triple axle or tandem trailer for 30 o/l
FWIW:
Maxxis offers 15" trailer tires in Load Range D (8 ply) and Load Range E (10 ply).
http://www.maxxis.com/trailer/traile...nflation-chart
They are FANTASTIC tires. I own a few sets for my single axle boats and camper with 14" & 15" wheels.
If upgrading to 16" wheels/tires is not an option for some, 15" wheels with Load Range E Maxxis tires is a really good alternative.
I would not consider 14" tires on anything that long hauls, regardless of how many axles. That small of diameter means very high Rotations Per Mile. That translates to heat, and heat kills tires.
FWIW:
They are FANTASTIC tires. I own a few sets for my single axle boats and campers with 14 & 15" wheels.
good feedback guys thank a bunch ! the reason I was asking is because I scrubbed off the interior of all 4 tires bad last season but I know when backing and turning etc there is a lot of weight on the tires I just replaced them with D range tires so I will keep an eye on them to see if they start to wear fast then I might have a bent axle or something wrong ! not sure how many season a tire should last ,I trailer everywhere and l;ots of sharp turns to launch my boat in my town here so maybe its normal,thanks again for all the great info
Most trailer tires dry out before they wear out. I cover my trailer tires to keep the sun off of them. It makes a big difference. Make sure they were inflated properly. A deflated tire will run warmer which leads to problems.
Also try to avoid dragging the tires side ways when you are backing up. That beats the tires up as well. When I'm done washing the boat I spray the road and my driveway down with water to let the tread slip some as I'm backing up my driveway . I don't get the rubber marks on the pavement that way. I have friends that make sure they keep a little sand on the pavement to help the tires slide. I prefer the water method as it's cleaner.
^^^everything that he said!
That's one of the reasons much of my driveway is staying gravel. It's more forgiving.
Also, DO NOT park tires on grass! That's terrible for them. If you have a regular place you park your boat which is grass, buy some 2x12s and cut to size.
Average lifespan of a tire is 7 years, weather it sits in a CostCo warehause for 6.5 of them or in your driveway for all 7. Learn to read tire date codes!
Disc brakes are the way to go. If you are switching, don't forget to buy the reverse lockout solenoid. You won't be able to back up the trailer up any incline without locking up the wheels once you go to disc.
