Did I Get A Killer Deal? >
Old 10-03-2015, 04:17 PM
454 Mag MPI
Baja226sport is offline
Old 10-03-2015, 09:40 PM
Originally Posted by Baja226sport
454 Mag MPI
There is also a 7.4 LX motor also. Its the 330 hp. Looks like the mag mpi intake, but says 7.4 LX on the top.
nailit is offline
Old 10-04-2015, 08:06 AM
This is true, made only in 1996-97. It will in fact say LX on top of the plenum.
Old 10-04-2015, 08:41 AM
Congrats on your new boat, enjoy!
Feverz29 is offline
Old 10-04-2015, 09:29 AM
7.4 MPI 310 hp
454 Mag MPI
Bingo, that's what mine says on the plenums, (7.4 LX) guess I'm right in the middle.
Thanks for all the above responses.
Thanks!
Tractionless is offline
Old 10-05-2015, 01:18 PM
Originally Posted by Tractionless
How do I tell the difference?
The boat will not be in my possession for 2 more weeks. Its going directly to the upholstery shop 150 miles away to get freshened up.
CHECK YOUR DECK HATCHES AND CLEATS FOR LEAKS WHILE YOU'VE GOT HEADLINER OUT
NADA SAYS YOU GOT A DEAL -BUT YOU CANT BE SURE 'TIL YOU POST PICS ON OSO AND GET IT BOARD APPROVED
SOUNDS LIKE YOU SCORED-ENJOY IT
JETTDOGG is offline
Old 10-05-2015, 03:09 PM
What killed the price is the LX engines. Plus it is a laundry list of small things to do on it. Do the work your self you will be money ahead .
92nsx is offline
Old 10-10-2015, 09:32 AM
Im pretty sure they had a bravo peanut port tbi ,vortec head mpi, efi mag weber carb mag all in that 96-97 span .the difference between a ho hum 454tbi and a good 7.4 mpi could seem like alot more than 20hp. Dont know if the tbi (7.4 efi) was offered in the baja. Its more of a b3 big boat kind of mill
airjunky is offline
Old 10-10-2015, 09:36 AM
You may already have cockpit floor drains that go under the bench into the bildge. If not it would be a good time to add them if seat cushions and hatch covers are off
airjunky is offline
Old 10-12-2015, 11:24 AM
I saw the boat late last week and got a estimate on the HL as well as where it comes down on the walls to the top of the wrap around seat, V-berth, counter etc. The upholstery shop wanted $2500-$3000 to replace it with a material I absolutely hated. They said they will not put vinyl in for headliners etc. The material was like a low pile carpet with whiskers, cream color (my cabin is white/gray), and IMO had a 1980's feel to it. Going to attempt to put the HL back up in the 2 places where it's starting to fall and clean the surface mildew from it. There is zero water damage to the HL, just the aforementioned for being shut up and not used in a humid environment for 1.5 yrs.
In the cabin pic below the v-berth cushions are being changed to new with the center 2 being white vinyl and the outer 2 wedges gray to match the accents on the wrap around seat. The carpet is being replaced with a lower pile, similar color and a cockpit carpet is being made of the same material.
https://im1.shutterfly.com/media/47a...D550/ry%3D400/
Can see where corner is falling here. Burner and counter step will be deleted.
From the issues I heard of with the Mag's I'm not so sure I'm mad about being 55hp down per engine.
The work is being down by myself with the assitance and know how of a friend who is a career marine mechanic/electronics wiz. All parts are at cost +5% or so. Things like refrigerators that they have sitting around at their shop which are new and other's had removed to add storage will be below cost. All labor is free, of course I'll hook him up for the holiday's etc.
I'm with ya. I saw the boat late last week and the bench seat bottom is good as is the sun deck. The back that wraps around to arm rests needs rebuilding and the cup holders which continue onto the cockpit walls do as well. The latter will be pulled altogether and made flat like the panel above it to gain space and simplify the job.
Here's some general pics.
