Easy Upgrade and inexpensive!
I just ran across this thread from Too Old.
These things really make a difference if you have the cheap-o white plastic ones.
http://www.offshoreonly.com/forums/s...threadid=76295
(By the way, I dont work for Too Old, just think these are worth checking out!)
Charter Member #300
No that I'm a cheap bastard ('cause I am), but I spray painted mine with engine enamel (purple) of all things and they have help up fine for two years so far.
I did it as a whim intending to replace all four...
They are not glued but they are about impossible to remove without destroying. I finally just broke mine and pulled it out. Then you will have to remove the staples out of the vinyl and take a dremel tool or something too make the opening a little larger. Because they will not fit in the existing opening, or at least mine did not.
I ordered two for the front today and If I can get the back ones out with out f-ing up the vinyl then I will get two more. How long did it take to get yours?
Charter Member #34
1 Post
We did blue in the cockpit and silver in the cuddy.
Went one step farther and added blue LED lights in the bottom of the cup holders. Looks really cool when you are at the docks at night!
