imco shortie
#31
Re: imco shortie
well I dont no what happened to MY reply to ALLEN4 yesterday its gone my membership isnt working so ALLEN4 CALL ME OR REPLY WITH A PHONE # I CALL YOU ABOUT THE STEERING MY # CELL 617 833 3327 HOME 508 230 8607 IM STAY AWAY FOR A FEW DAYS UNTIL THEY GET THIS SITE RUNNING RIGHT NO NUDES FOR ME
#35
Re: imco shortie
Baja36ft,
Even if you go up to a 28 pitch I think you will find you still need to go to a five blade to make your combination work. PPlay is correct if you go up to a 28 you will pick up speed but you will still be slipping a lot. You will also find that if you needed a 28 pitch 4-blade you probably will not be able to turn a 28 pitch 5-blade the same rpm. If you can try a 26 and a 28 pitch 5-blade, one of them should solve your problem. I used to run a 30 pitch lab finished 4-blade Bravo 1. I now run a 28 pitch 6-blade Herring. I tried a 30 pitch 5-blade and I couldn't turn the rpm I needed.
Let us know when you get a chance to run with the 5-blades.
Drill It
Drill It
#36
Re: imco shortie
I sure will let everyone know when i try the 5 blades right know it's to cold to do anything
thanks for everyone's help julie has a set of 5 blades 27 pitch i can try,.
