Go Back   Offshoreonly.com > Owner's Forum > Baja
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 02-07-2005, 03:03 PM   #1
yzbert's Avatar
2003 37 Active Thunder
anyone else with hinge problems on cabin couches?
with mine the pins keep coming out and the seat cusions get loose/fall off. anyone with the same problem? and how did you fix it? 1999 36 outlaw
yzbert is offline   Reply With Quote
Old 02-07-2005, 03:53 PM   #2
Charter Member #34
Dock Holiday's Avatar
Re: anyone else with hinge problems on cabin couches?
Yeap! Had exactly the same problem, one hinge on each bench. About everytime we went out a pin would fall out and the wife would complain!
Found a real cheap, simple solution that worked like a charm.
Went to Lowes Hardware, and bought what I call a hitch pin.
It is a pin the is straight, then on one end it curves back around and contacts the main part and curves back away from it.
It was the right diameter and length, drove it in with a little help of a hammer and they have been in there over a year with no problems.
Maybe I should call it the CLIP that is used on the hitch pin.
Check out this link, it is the clip. http://www.mm-inet.com/new/751953.htm
Give it a try.
Dock
Dock Holiday is offline   Reply With Quote
Sponsored Links
Old 02-07-2005, 04:01 PM   #3
yzbert's Avatar
thanks doc i will give it a try
Trackbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Removing the cabin couches on a 38 Lightning Viaqua Fountain 8 07-11-2006 07:56 AM
hatch hinge...over or under???? 88formula223 Formula 7 06-12-2006 01:42 PM
speedmaster hinge pins boatman747 General Q & A 4 03-28-2006 07:46 PM
Alpha hinge pins jhnrckr General Q & A 3 03-17-2004 07:21 PM
Search Engine Optimization by vBSEO 3.2.0
