| OSO Sponsor |
| OSO Sponsor |
02-12-2005, 07:01 PM
1995 Baja 32' Caliber
Bravo Drive Lube Amount ?
I changed the drive lube on my last boat and forget how many ounces(quarts) it takes, could some one refresh my memory?
02-12-2005, 08:38 PM
'05 Fountain 35 EX
Re: Bravo Drive Lube Amount ?
88 ounces per the manual...I also made a quick refill tank out of a 1.5 gallon garden sprayer (Home Depot, $11.00) works great.
You never slow down, you never grow old...Tom Petty
02-13-2005, 09:28 AM
Thanks !!!!!!!!!!!!!!
02-13-2005, 05:42 PM
Charter Member #34
Start at the bottom, when it gets the vent plug on the side, put it back in, and keep filling until it gets to the top line on the bottle.
02-13-2005, 06:12 PM
2001 baja outlaw 33
Quote:
MORE INFO MORE INFO Explain yourself
02-13-2005, 07:27 PM
2005 PQ Revenge..496 HOs
Quote:
Istall the fitting that screws into the out drive to the
deck sprayer hose,fill the sprayer with gear oil,you pump the deck sprayer up with pressure and let it do the work and fill the out drive.
02-13-2005, 07:40 PM
1999, Baja 36 Outlaw, HP 500's
2.8 quarts including reservoir.
And yea -- all the above!!
Mark
02-14-2005, 10:05 AM
'05 Fountain 35 EX
You do have to have (or buy) the hose with the fitting that couples to the drive to make an aftermarket deck/garden sprayer usable. The pump kit costs around ten bucks and can be bought at any Mercury Marine dealer. It's a simple matter of connecting the hose end to the sprayer (usually a like size) and connecting it to the drive, all else is as boatnt says..this really saves alot of time and mess. It really works great with synthetic gear lube but that is another story! Best of luck.
G-
02-14-2005, 06:04 PM
2001 baja outlaw 33
thankyou, I've been pumping for what seems like forever with the little pump that fits on the quart bottle thinking there had to be a better way.  now does anybody have a simple way to remove and reinstall the drives????
02-14-2005, 07:33 PM
Removing them is easy...I assume the problem your talking about is when you try to get the spline to line back up with the coupler...is thats what you mean try this ...disconect the coil, have someone crank the engine over while your pushing the drive, it will fall right in place ! I have removed the drives on my last two boats and can take then off in 5 minutes and reinstall them in 5 minutes.
Similar Threads
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Amount of Lube in Bravo Unit?
Rebel_Heart |
Drives and Lower Units |
1 |
09-25-2008 03:17 PM |
drive lube
1 MAIDEN AMERICA |
2 |
11-05-2007 08:42 AM |
Drive Lube
nordic95 |
General Q & A |
5 |
11-23-2006 06:06 AM |
